configure automation edge connect/disconnect
configure automation edge [connect | disconnect] database database_name
Description
Connects or disconnects an Automation Edge remote VXLAN network identifier (VNI)-device database.
Syntax Description
automation Designates configuring Automation Edge VXLAN VNI-device database information.
edge Designates configuring Automation Edge VXLAN VNI-device database information.
connect Designates connecting to the specified database.
disconnect Designates disconnecting from the specified database.
database Designates connecting or disconnecting a database.
database_name Sets the database name that you are connecting or disconnecting.
Default
N/A.
Usage Guidelines
To connect to another new database, an existing database must be disconnected first. To view the connected database, use the command show database database_name
The following example connects the database "database1":
# configure automation edge connect database database1
The following example disconnects the database "database1":
# configure automation edge disconnect database database1
This command was first available in ExtremeXOS 31.1 as a demonstration feature.
This command is fully supported in ExtremeXOS 31.2.
Platform Availability
